Please consider supporting us by disabling your ad blocker or buy PlayOn (record Netflix) :)
  1. Alot of the dvds that I burn sometimes get dirty. Do I clean the dvds the same way I would clean a cd disc. Or can I clean them with those cleaning cloths, that you use to clean cd discs. Is there a way to clean burnt dvd discs?
    Thank you
    Corey
    May 2003
    Pal Realm
    I just use a lint-free cloth - like the type made for CDs - and wipe from the hub out to the edge - in straight lines. No problems so far. :c)
    I always check for any lint or dust before I use it. I just blow on it. :c) Not very high-tech, but it works. :c)
    There's no place like 127.0.0.1
    The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts.
