The latest version of AnyDVD software will allow one to adjust the drive speed of both the player and writer, there are 3 different speeds. My question is this, will adjusting these speeds all the way up or all the way down effect the video/audio quality of the burned copy of a movie DVD? Thank you.
Depends on the drive!
- Gurm
Gurm thanks for reply, I am using Pioneer DVD 105 Rom and Plextor PX708A writer, windows xp, athlon 2600xp, 512 ddr ram. I am more concerned with quality vs. speed but if running max speed with AnyDVD settings will not affect quality then I would like to speed things up but not at the reduction of quality. Thanks for your help and advice.
With a Pioneer DVD-ROM or a Plextor DVD burner, assuming the rest of your system is fast enough, you can run fullspeed with no problems at all.
The settings might ALSO be to reduce noise, I dunno how LOUD the Pioneer is at full speed.
- Gurm
Question about Anydvd and bluray ripping...
By AndyD in forum Blu-ray RippingReplies: 0Last Post: 13th Mar 2010, 19:05 -
A question about the use of anydvd
By wizang in forum Blu-ray RippingReplies: 5Last Post: 1st Sep 2009, 15:14 -
AnyDVD & AnyDVD HD 6.1.8.4 final
By devilcoelhodog in forum Latest Video NewsReplies: 0Last Post: 11th Oct 2007, 21:27 -
Problem AnyDVD version 6.1.6.5 d/l overtop 6.1.5.5 won't work????
By vanc in forum Newbie / General discussionsReplies: 0Last Post: 29th Jun 2007, 19:54 -
Silly Question About AnyDVD
By hech54 in forum DVD RippingReplies: 3Last Post: 10th May 2007, 01:29
