i have a few question abt dazzle dvc100..
1. i have a few captures which each are +/-40 mins. i was wondering if there's any way i can squeeze in +/-80 mins onto a 700mb cd-r? i'm trying to make it seemless so when one part is done, the next part will start immediately. it'll be played on a stand-alone dvd player. in short, is there anyway to compress mpeg (vcd quality) files that were captured so they can fit on one 700mb cd-r?
2. how do i trim/edit the video cause i started the capture a few secs before the source started and stopped a few secs after the source is done. i couldn't seem to be able to figure that out. i read the manual, but i wasn't able to do it.
3. i tred adjusting the brightness, contrast, hue, and saturation before starting the capture, but there's no way i can make it same as the orig. is this normal or is it possible to make it exactly? sometimes it's really close to the orig, but if there's a scene that has a really dark bg, the captured one will change into a black bg. and if the orig is very bright (trees under the sunlight, etc), when it's captured, you can't see any tree, and only see a blob of yellowish color.
4. how do i use the features? seems like most of them are either disabled or at least i can't get them to work. i tried following the manual, but it's just not working.
btw, i'm using moviestar 5 for the capture.
Results 1 to 1 of 1
Thread: need help with dazzle dvc100
Dazzle DVC100 BFF vs. TFF
By Zabar12 in forum CapturingReplies: 13Last Post: 12th Jan 2012, 06:29 -
Dazzle DVC100 Interlacing Problems
By Imatk in forum CapturingReplies: 1Last Post: 25th Jul 2011, 18:25 -
Unable to convert NTSC VHS to DVD - Dazzle DVC100
By tkexer in forum CapturingReplies: 4Last Post: 20th Jun 2011, 09:29 -
problems capturing with dazzle DVC100 and s-video no color
By rekotc in forum CapturingReplies: 14Last Post: 23rd Dec 2010, 04:56 -
No Sound With Dazzle DVC100 using Virtual Dub
By kpoman in forum CapturingReplies: 3Last Post: 3rd Nov 2009, 08:35
