VideoHelp.com Forum
Thread: Stills
    Does anyone know of a free program that I can use to extract still images from VOB's or MPEG's. I want to use extracted stills from my movies to create covers for my holders, and labels for my DVD's.
    Theres another good question; does anyone know if the glue from the cd labels will ruin the coating on a DVDR over time?
    thanks
    Papadeath
  2. Member unclebud's Avatar
    Q1 Most computer DVD player software has a screen capture utility built in. Try downloading the trial version of WinDVD or PowerDVD. Each should do what you want.
    Q2 Adhesive Labels on DVD's are a bad idea, out of balance from the label and heat generated in DVD players will cause the labeled DVD to fail to play. Use a Sharpie or get a printer that will print on printable DVD's.
  1. taking stills from video
    By angryassdrummer in forum Newbie / General discussions
    Last Post: 24th Oct 2011, 01:53
  2. Dissolving between stills
    By solarblast in forum Editing
    Last Post: 11th Mar 2011, 10:11
  3. Best way to add stills to audio
    By PrepositionJoe in forum Newbie / General discussions
    Last Post: 8th Jun 2010, 04:53
  4. 881017 - taking stills
    By hamidi2 in forum Newbie / General discussions
    Last Post: 7th Jan 2010, 08:26
  5. Playing Stills and Video on a TV??
    By reman in forum Newbie / General discussions
    Last Post: 2nd Oct 2008, 14:27
