VideoHelp.com Forum
Thread: Video Encoding
  1. I'm a MEGA Super Moderator Baldrick's Avatar
    The process for changing a video from one format to another by altering the resolution and/or the bitrate. Normally the result of this process is a movie with a different compression. For a proper encoding you need a piece of software and/or hardware, which is called codec.
    What are 8 bit, 9 bit, 10 bit, and 12 bit video converters employed in hardware DVD players? I have found an article on the web which says that a 10 bit video converter gives 4 times the clarity of an 8 bit converter. Is this true? If so, where do 12 bit video converters fit in? Given a choice between a DVD player having 10 bit video converter, and another having 12 bit video converter, which is likely to give better picture clarity? If higher bit rate gives better video performance, then why is everybody not following the same format?
    I am confused. Please clarify. :?
  1. Replies: 11
    Last Post: 2nd Mar 2012, 20:28
  2. Video Encoding
    By Datson in forum Video Conversion
    Last Post: 24th Jan 2012, 13:27
  3. Replies: 12
    Last Post: 21st Oct 2009, 17:37
  4. New to video encoding.
    By pickledpacman in forum Video Conversion
    Last Post: 25th Mar 2009, 10:39
  5. Best Video Encoding?
    By mvtm in forum Mac
    Last Post: 15th Mar 2009, 13:56
