VideoHelp.com Forum
    Thanks for the time...
    Here in my country, PixelView PlayTV Pro cost $60...and PixelView PlayTV PVR cost $100.
    What PixelView PlayTV PVR have that is worth more $40 ? What is the main difference ? I could use Scheduled Recorder with PixelView PlayTV Pro too ?
    PixelView PlayTV PVR info...
    http://www.prolink.com.tw/english/pr...AYTV%20PVR.htm
    PixelView PlayTV Pro info...
    http://www.prolink.com.tw/english/pr...aytv%20pro.htm
    Thanks in advance.
  2. I don't know anything about tv play cds from prolink
    I do know i bought thier pixelview xcapture PV-CX881P card at newegg
    Was recomenned but they said trouble installing the drivers
    I tried every way i knew with no luck
    The install disk won't install it
    I called prolink and they are useless won't help you
    Also tried drivers from thier site with no luck
    Small no detail users manual
    My Advice before u buy anything from them check it out if you buy it make sure you can return it-try to use it right away because you can return it to newegg before 30 days ok? Good Luck
    PS i'am a newbie I'll probly have somebody install it for me because i'm stuck with it-possible defective part
    Bob
  1. Replies: 2
    Last Post: 25th Mar 2010, 08:13
  2. Replies: 4
    Last Post: 18th Nov 2009, 04:53
  3. pixelview tv capture card
    By oldboy29 in forum Computer
    Last Post: 5th May 2009, 17:42
  4. Pixelview capture card under XP
    By Greycat in forum Capturing
    Last Post: 23rd Apr 2008, 15:11
  5. PixelView PlayTVpro: Composite video signal not captured
    By faisalshafait in forum Capturing
    Last Post: 1st Nov 2007, 14:42
