VideoHelp.com Forum
Thread: Daewoo P80S
  1. I'm from switzerland, and i bought here a DVD player named P80S from Daewoo.
    I search for a regionfree hack. But that player didn't exist in the whole internet. So i find nothing about it.
    Can anyone help me.
  2. Hi,
    I am from Switzerland too. Bought the same unit and the crack is:
    Using your remote, power on:
    1. Open tray
    2. Press setup
    3. Go to preferences (last menu item on the right)
    4. Scroll down to the last item in the list
    5. Press 1, 3, 7, 9
    This will give you access to the region code. Change to '0' to make your player zone free.
    Enjoy !
  3. The 1,3,7,9 crack doesn't function on my DVD Player. So i search for other cracks. And i found, that the AMW P80L and the Ronin DVD P807 use a crack that function with the p80s.
    1. Press SETUP on Remote Control
    2. Enter 13798888
    3. Select VERSION from the menu by pressing ENTER
    4. On REGIONAL CODE press RIGHT (>) button
    5. Use DOWN button to change REGIONAL CODE to '0'
    6. Press ENTER on Remote Control to save
    Some of the new ones have a slightly different menu. This is one code that they changed. If your menu doesn't have a choice for preferences and region, this code might work on some of the newer Daewoo P80S:
    1. Open the disc tray
    2. Press menu (nothing really happens)
    3. Enter 2812
    4. Select region. Region 9 is the multi region instead of 0.
    5. Press menu again.
    Hope this helps someone.
  1. Daewoo DF4100P
    By hillneerg in forum DVD & Blu-ray Recorders
    Last Post: 19th Feb 2011, 11:06
  2. daewoo dv-1100a region free hack
    By noblegirl in forum DVD & Blu-ray Players
    Last Post: 6th Jun 2009, 18:18
  3. DVD recorder Daewoo DL-3100
    By Leonora in forum DVD & Blu-ray Recorders
    Last Post: 21st Apr 2009, 06:35
  4. Hack the Daewoo DS-K965
    By sonquilombo in forum DVD & Blu-ray Players
    Last Post: 3rd Jan 2009, 18:08
  5. DVD Daewoo DS-K960U
    By TonitoDJ in forum DVD & Blu-ray Players
    Last Post: 6th Oct 2008, 09:08
