Hey guys,
i forget what version of virtualdub i have, but its fairly recent... (im at university right now) and i was having some problems lately.
I formatted my hard-drive and re-installed virtual-dub... and no its setting its default recording device to my web-cam! lol.how do i change the primary recording device back to my video in capture card?
thx a bunch
-Syndrome
Start Virtualdub and select 'File' -> 'Capture AVI'.
In the capture window select 'Capture' -> 'Preferences', then select your device from the 'Default capture driver' drop-down list.
Tick the 'Save current capture settings as default' and press 'OK'.
(If your capture card is not in the drop-down list then you may have a driver problem).
Looking for capture device, is this what I need?
By V Bot in forum Capturing and VCRReplies: 3Last Post: 21st Apr 2012, 09:16 -
Capture device
By ingeborgdot in forum Capturing and VCRReplies: 7Last Post: 11th Sep 2011, 20:02 -
Device Capture - USB, Works With PAL / NTSC, Works with VirtualDub/VCR
By Drazick in forum Capturing and VCRReplies: 0Last Post: 7th Aug 2010, 18:27 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 04:31 -
capture device for hd
By jjjamiem in forum Newbie / General discussionsReplies: 2Last Post: 8th Aug 2007, 14:30
