VideoHelp.com Forum
  1. All.
    If you include subtitles on a backup does this effect the compression rate or not.
    e.g are the subtitle element(s) a massive file
    Thanks.
  2. Member SaSi's Avatar
    If you refer to the "proper" DVD subtitle streams that are selectable, then no, the impact is negligible. The average size of a compressed (2-bit RLE) subpicture is around 2kB. So, for a movie with 1,000 subtitles, you end up with 2Mb for the subtitles.
    The more I learn, the more I come to realize how little it is I know.
  3. SaSi
    Thank you.
    Smithy
  1. Question Re Subtitles in HDConvertToX
    By morphjk in forum Blu-ray Ripping
    Last Post: 10th Aug 2010, 07:19
  2. Another question about subtitles
    By du2vye in forum ffmpegX general discussion
    Last Post: 18th Oct 2009, 04:27
  3. Subtitles question
    By vanderbog in forum Subtitle
    Last Post: 8th Sep 2008, 00:11
  4. Subtitles Question
    By cowboysroy31 in forum Subtitle
    Last Post: 11th Jul 2007, 10:48
  5. Question about Subtitles.
    By vodmare in forum Authoring (DVD)
    Last Post: 13th May 2007, 07:38
