VideoHelp.com Forum
  1. I have some grainy footage on VHS that I'm going to encode (MPEG2).
    It's an old football game from 1967, that was transferred over from the original film.
    Overall, I'd have to say that the quality of the original is good, but as always, it could be better.
    Any tips out there from improving the quality? TMPGenc filters?
  2. Член BJ_M's Avatar
    noise reduction first off , then in color adjustment , pull out all colors ..
  3. Member SaSi's Avatar
    The Tmpgenc filters are slow. I would work with VirtualDUB to do filtering. There are several plug-in filters for the program and you can find the appropriate links in the tool section. Also do a google search for "virtualdub plugins" or "virtualdub plug-in", will reveal several more.
    As BJ_M suggested, do softening. I would remove colors at the end. I'm not sure if I'm correct - so BJ_M if you are listening, please comment:
    I suggest to decolorize at the end because even if color is not good quality, the RGB space conveys some luminance information (gammut?) that would be lost if you totally de-saturate making the 24bit information into 8 bit.
    I would therefore do softening, smoothering, perhaps even temporal softening first and then decolorize, in the same way one scans an image at high resolution, work filters and retouches it and then reduces resolution to the wanted size.
    The more I learn, the more I come to realize how little it is I know.
  1. Best filters to Improve Video?
    By mlong30 in forum Restoration
    Last Post: 13th Mar 2012, 09:18
  2. "Greenish" Black & White To "True(r)" Black & White?
    By DeathStalker77 in forum Restoration
    Last Post: 30th Jul 2011, 08:39
  3. help choosing filters to improve quality
    By anajat in forum Newbie / General discussions
    Last Post: 28th Jul 2011, 06:10
  4. black and white
    By foofie131 in forum Newbie / General discussions
    Last Post: 24th Mar 2011, 21:15
  5. Replies: 38
    Last Post: 12th Aug 2009, 17:09
