hi there, as mentioned in the header, i cant get my Denver 156 DVD player to play from DVD+R disc i burned. i tried to burn on DVD+RW disc from the exact same image, and no problems there at all.
How can i solve this ? If i have to burn all my movies on RW's its going to be VERY expensive.
plz help
Psico
Thread: Denver 156 cant play from DVD+R
I would suggest trying a different brand of DVD+R and see if that helps. According to the compatability list that player should play DVD+R
hi, thanks for your suggeestion, appreciate it. But according to one of the people that posted under that DVD player, he mentions that it can only play DVD+R if its burned in DVD-RAM mode. How can i get my burner to burn in that format ?
I think what you meant was if it was burnt using Dvd-Rom Book type it would play. What make of burner are you using as it is important because bitsetting read here http://dvdplusrw.org/resources/bitsettings.html
http://dvdplusrw.org/resources/bitsettings_pc.html
damn.
I have a Lite-on drive, and a denver 156 stand alone, guess there is no way at all to use DVD+R discs to record on and watch on the Denver.
Dang it
What DVD+R media (media code too) are you using?
BTW: $40 cheapo players usually play anything you throw at themYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 16:32 -
DVD will play on new DVD player, but won't play on old
By joe8915 in forum Video ConversionReplies: 9Last Post: 18th Feb 2008, 18:57 -
Question about Denver
By fruity_player in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Jan 2008, 07:18 -
Can a dvd player that able to play dvd+r dl play dvd-r dl or does this vary
By dymx in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Oct 2007, 14:33 -
By dymx in forum DVD RippingReplies: 1Last Post: 22nd Oct 2007, 11:30
