I'm very new to these programs and have tried to follow numerous guides as well as searching this site and doom9 ect...
My mind is now swimming with programs, extensions ways of encodeing and the answers I need are probably obvous but I'm just too bloody frusterated to see them.
I have been having huge problems with avisynth script. (nothing is working.)
I even tried http://www.avisynth.org/index.php?page=YourFirstScript As you may notice it is entitled your first script and it does not even work for me.
Searching this forum I found a simple? test
When I typed "version" in notepad (as suggested in this thread http://www.dvdrhelp.com/forum/viewto...visynth#649775 ) nothing came up for me in virtualdub.
I did save it as an .avs file and I did change the .txt to *.*. I even saved it as tweedledee just incase (The problems I have had lately have told me that nothing is impossible and just do it EXACTLY as described or it will NOT work.)
I am using virtualdub 1.5.4.
If anybody has any thoughts about getting it to work so I can resize some video, use cce and burn it I would appreciate it.
-Thanks.
Thread: avisynth script help
Did you install avisynth.dll in your system32 folder, and did you install it in the registry?
Hello.
Thanks for the reply- I'm currently rebuilding an engine so I only have time to check back periodically.
When I downloaded avisynth2.52 it installed aivsynth.dll when I unpacked it. I think it must do the registry as well because the only thing in the file avisynth2.52 are webpages, examples and the user agreement (licence.)
Should i use and avisynth script for Dv ?
By smartel in forum Newbie / General discussionsReplies: 0Last Post: 10th Mar 2012, 08:29 -
Need Help with My AviSynth Script
By Enkidu in forum Newbie / General discussionsReplies: 3Last Post: 21st Jan 2011, 21:37 -
Avisynth Script Help
By jamhat in forum Video ConversionReplies: 2Last Post: 29th Nov 2009, 06:13 -
Avisynth script
By daz2712 in forum Video ConversionReplies: 2Last Post: 19th Aug 2009, 11:08 -
avisynth script
By magenta2007 in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 25th Sep 2007, 11:29
Statistics
Newest guides
Latest tool updates
New media comments
