I am getting the following error whenever I use the kvcd preset:
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
**ERROR: [mplex] Unable to open file /Users/tokyotony/Desktop/MusicVideo/Eurthmyics-Rain Again kvcd.dv.m1v for reading.
Any ideas?
spaces in the name of the file?
Try to use a shorter pathname (ie less nested folders and shorter filenames).
Thanks for the advice. I have shortened the name to only 2 letters and put the test folder as high as possible. I still get this error:
**ERROR: [mplex] Unable to open file /Volumes/MovieProjects/MusicVideoTest/EA.m2v for reading.
And, I do notice that there is not EA.m2v file created anyway.
Hmmmm....
Guestsame problem here with an divx file 2 kvcd
jt77 8)
Please email me to major4@mac.com with the whole process output.
Guestok silly me i installed the old mpeg2enc encoder ...
that was the problem works just fine now ...
jt77 8)
Well, after installing 8c, I'm no longer getting the same error, but now a new one:
INFO: [mplex] SYSTEMS/PROGRAM stream:
**ERROR: [mplex] Variable bit-rate stream present: output stream (max) data-rate *must* be specified!
The complete terminal dialog is as follows:
Encoding started on Mon Sep 15 20:55:27 JST 2003
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
Input #0, dv, from '/Users/tokyotony/Desktop/MusicVideo/ABC-When Smokey Sings.dv':
Stream #0.0: Video: dvvideo, 720x480, 29.97 fps, 800 kb/s
Stream #0.1: Audio: dvaudio, 48000 Hz, stereo, 1536 kb/s
Output #0, yuv4mpegpipe, to 'pipe:':
Stream #0.0: Video: rawvideo, yuv420p, 352x480, 29.97 fps, q=2-31, 200 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Press [q] to stop encoding
INFO: [mpeg2enc] Selecting generic MPEG1 output profile
INFO: [mpeg2enc] Encoding MPEG-1 video to /Users/tokyotony/Desktop/MusicVideo/ABC-When Smokey Sings KVCD.m1v
INFO: [mpeg2enc] Horizontal size: 352 pel
INFO: [mpeg2enc] Vertical size: 480 pel
INFO: [mpeg2enc] Aspect ratio code: 1 = 1:1 (square pixels)
INFO: [mpeg2enc] Frame rate code: 4 = 30000.0/1001.0 (NTSC VIDEO)
INFO: [mpeg2enc] Bitrate: 1800 KBit/s
INFO: [mpeg2enc] Quality factor: 5 (Quantisation = 5) (1=best, 31=worst)
INFO: [mpeg2enc] Field order for input: none/progressive
INFO: [mpeg2enc] Sequence unlimited length
INFO: [mpeg2enc] Search radius: 16
INFO: [mpeg2enc] GOP SIZE RANGE 24 TO 24
INFO: [mpeg2enc] Setting colour/gamma parameters to "unspecified"
INFO: [mpeg2enc] Progressive format frames = 1
INFO: [mpeg2enc] size - setting constrained_parameters_flag = 0
INFO: [mpeg2enc] mpeg1 - setting intra_dc_precision = 0
INFO: [mpeg2enc] KVCD Notch Quantization Matrix
INFO: [mpeg2enc] Buffering 57 frames
INFO: [mpeg2enc] SETTING AltiVec for QUANTIZER!
INFO: [mpeg2enc] SETTING AltiVec for MOTION!
INFO: [mpeg2enc] SETTING AltiVec for TRANSFORM!
INFO: [mpeg2enc] SETTING AltiVec for PREDICTION!
INFO: [mpeg2enc] Guesstimated final muxed size = 56796396
## Component Manager: attempting to find symbols in a component alias of type (regR/carP/x!bt)
INFO: Opened WAV file, freq = 48000 Hz, channels = 2, bits = 16
INFO: format = 0x1, audio length = 49021768 bytes
INFO: slots/frame = 417
INFO: Fractional number of slots, padding required
INFO: System is big endian
INFO: Avg slots/frame = Inf; b/smp = Inf; br = Inf kbps
INFO: Encoding with psychoacoustic model 2 is finished
INFO: The MPEG encoded output file name is "/Users/tokyotony/Desktop/MusicVideo/ABC-When Smokey Sings KVCD.mp2"
INFO: [mplex] File /Users/tokyotony/Desktop/MusicVideo/ABC-When Smokey Sings KVCD.m1v looks like an MPEG Video stream.
INFO: [mplex] File /Users/tokyotony/Desktop/MusicVideo/ABC-When Smokey Sings KVCD.mp2 looks like an MPEG Audio stream.
INFO: [mplex] Found 1 audio streams and 1 video streams
INFO: [mplex] Selecting generic MPEG1 output profile
INFO: [mplex] Multiplexing video program stream!
INFO: [mplex] Scanning for header info: Video stream e0 (/Users/tokyotony/Desktop/MusicVideo/ABC-When Smokey Sings KVCD.m1v)
INFO: [mplex] VIDEO STREAM: e0
INFO: [mplex] Frame width : 352
INFO: [mplex] Frame height : 480
INFO: [mplex] Aspect ratio : 1:1 (square pixels)
INFO: [mplex] Picture rate : 29.970 frames/sec
INFO: [mplex] Bit rate : variable
INFO: [mplex] Vbv buffer size : 63488 bytes
INFO: [mplex] CSPF : 0
INFO: [mplex] Scanning for header info: Audio stream c0 (/Users/tokyotony/Desktop/MusicVideo/ABC-When Smokey Sings KVCD.mp2)
INFO: [mplex] MPEG AUDIO STREAM: c0
INFO: [mplex] Audio version : 1.0
INFO: [mplex] Layer : 2
INFO: [mplex] CRC checksums : no
INFO: [mplex] Bit rate : 16384 bytes/sec (128 kbit/sec)
INFO: [mplex] Frequency : 44100 Hz
INFO: [mplex] Mode : 0 stereo
INFO: [mplex] Mode extension : 0
INFO: [mplex] Copyright bit : 0 no copyright
INFO: [mplex] Original/Copy : 0 copy
INFO: [mplex] Emphasis : 0 none
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
For those who face the "windows media player cannot open this file" problem
By sanosuke in forum Software PlayingReplies: 0Last Post: 1st May 2011, 08:00 -
Problem with burning DVDs on Power2g, "not a valid file" error, please help
By DaneClark in forum Authoring (DVD)Replies: 1Last Post: 7th May 2010, 19:19 -
WebEx WMV file, can't open in VirtualDub, says "missing codec"
By violetta in forum Newbie / General discussionsReplies: 11Last Post: 22nd Mar 2010, 14:37 -
Camtasia Error : "Unable to write AVI file frame"
By ShinuMirai in forum Newbie / General discussionsReplies: 8Last Post: 11th Oct 2009, 15:19
