VideoHelp.com Forum
    I have a couple of XviD movies. When I put them straight into TMPGEnc and I see the movie length in the Media screen then it shows a film twice the size. If I try to encode it twice by splitting the screen TMPGEnc shutsdown.
    Any help?
  2. Member bugster's Avatar
    Open the avi in virtualdub, if it gives a warning about VBR audio (TmpGenc does not like this), then use vdub to save out the audio as an uncompressed wav file, then use this as the audio source when you encode with Tmpgenc.
    Hope this helps
    Bugster
  3. I did not know that this could be the reason. I know that my file has this vbr error. By the way, will my mpg contain that much audio no matter from which source format I will convert? (Wav, mp3 or whatever?
    I will give it a try when I am at home.
  1. Sony Vegas Pro mpeg rendering size larger than movie studio
    By bbbbbbb45 in forum Newbie / General discussions
    Last Post: 17th Jan 2012, 12:31
  2. NTSC -> PAL same movie length?
    By busta3396 in forum Mac
    Last Post: 6th Mar 2010, 06:30
  3. movie length into a avchd dvd9
    By supersam in forum Authoring (Blu-ray)
    Last Post: 14th Oct 2009, 00:42
  4. TMPGEnc Issues with length of movie?
    By doctorgonzo in forum Video Conversion
    Last Post: 11th Apr 2009, 10:30
  5. Replies: 2
    Last Post: 22nd Sep 2008, 17:43
