I've seen several hardware capture cards (MPEG-2 and MPEG-1) talked about on the various boards here at VCDHelper, including
Dazzle DVC II
TrueBlue
AIW Radeon
etc...
I know there are many mpre capturing boards than the few listed here. My question is this: where would I go to read about them? See reviews? Purchase? Something was mentioned about a Pinnacle DV500 plus (or something similar) some time ago. Is that a good board? How much?
I'm not looking to spend alot, but I know this can easily get into the thousands of dollars for the higher end solutions.
I'm currently thinking about getting a Dazzle DVC II card or AIW Radeon to help capture video. Somewhere there was a Dazzle Hollywood (?) unit that let you connect your composite cables into it, and converted the analog video from an external source to DV. This unit cost a little more than a DVC II. Would that be a better solution than the DVC II?
So many questions, so little time... ;^)
TIA
try browsing the 'capture cards' section to your left there.
it doesnt contain any professional reviews, but it does contain comments an opinions from ppl who use them on a day to day basis, and a good web shop price compare (only useful in the US though
DV500 Plus best out there but will run around $600.
watch on the dazzle products if you are using AMD Duron or Athlon, their web site warns that it not work with these processors.
Buy the Matrox RT2500 all the way don't waste your money on Radeon or Dazzle.
Feel my Power Flaming Black Dragon Wave!!!!
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>Can you explain Why?
Hi8 capture- Suggestions for Harddrives and Capture Cards?
By CMP1223 in forum CapturingReplies: 7Last Post: 10th Jun 2011, 23:05 -
What's new in capture cards for VHS capture?
By chowmein in forum CapturingReplies: 21Last Post: 29th Jul 2010, 08:03 -
Hardware MPEG-2 encoder cards
By cybertheque in forum Video ConversionReplies: 20Last Post: 20th Oct 2008, 19:51 -
Capture Cards with hardware compression to Xvid/Divx?
By quantass in forum CapturingReplies: 7Last Post: 31st Aug 2008, 19:50 -
need info about sli graphic cards and video editing
By JerryB in forum ComputerReplies: 6Last Post: 9th Jan 2008, 21:14
