I capture VHS with WinDV and the result are very good. Somehow, since the sources are from VHS, I expected there are noises present. After re-encode to VCD with TmpgEnc, I like the result BUT I still want to get less noise a little more.
Are there otherway to capture with noise reduction while capturing????
thanks
how many times has this been posted ?
DV is not capture but a file transfer ... you have to post proccess it only ..
use the noise reduction filter in tmpgenc ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
thanks BJ
I try to import the file into virtual dub for process but it refuse to import. It said VFW codecs something????
Any ideas to fix this.
thanks
You need to install a DV codec that supports Video For Windows (VFW) which is what VirtualDub is compatible with. The Panasonic and Mainconcept codecs both work well (I haven't had much luck with the Canopus one for some reason). Check the tools section of this website for availability.
I personally prefer AVISynth for frameserving into TMPGEnc but you'll still need a codec.
Can I use a U.S Canopus ADVC-100 in the U.K?
By jedi55 in forum CapturingReplies: 32Last Post: 11th Mar 2011, 18:55 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD)Replies: 20Last Post: 16th Oct 2010, 20:52 -
Microsoft DV Camera and VCR/ Canopus ADVC 100
By BonnieW88 in forum CapturingReplies: 0Last Post: 27th Feb 2010, 17:26 -
How should I capture my hi 8 videos with my Canopus ADVC 100 and TRV460
By eichelman in forum CapturingReplies: 4Last Post: 9th Dec 2009, 13:21 -
Canopus ADVC-100 outputs
By datman in forum CapturingReplies: 2Last Post: 7th May 2007, 18:24
Statistics
Newest guides
Latest tool updates
New media comments
