VideoHelp.com Forum
Results 1 to 12 of 12
  1. noobie Q. How to play DVD on CD player?
    I genuflect to your knowledge and respectfully ask:
    I have a cd player on my laptop and PC and would like to play DVDs on them. I've been told that I need the codecs and a software program to do so. What do you experts suggests?
    Thanks for the help, in advance.
    Wins
  2. This CAN NOT be done. You need a DVD-ROM drive to play/read DVD media. CDs and DVDs might look the same but they are totally different technologies and use completely different lasers, formatting, etc.
    However, all DVD-ROM drives can also read CDs.
  3. You beat me to it... which is just as well, since I was completely prepared to give a smart-ass answer.
    No can do. Different laser wavelengths.
    Buy a DVD ROM drive.
    ICBM target coordinates:
    26° 14' 10.16"N -- 80° 16' 0.91"W
    This is true if the drive has dual lasers.
    Started this answer, but was called off to do some work - so, my answer is a duplicate.
  6. Or better yet, buy a DVD Burner and join in the fun!
    Just what is this reality thing anyway?
  7. ask your tech support people at work dont let them fob you off with any excuses!!
    The electronic components of the power part adopted a lot of Rubycons.
  8. Member ZippyP.'s Avatar
    Well...you can create a "back-up" of your DVD's to CD by creating a video CD (VCD) or Super-Video CD (SVCD). You would be able to play these on your computer's CD drive and on many home DVD players. Look in the "Articles" section for some good beginner information.
  9. I've been told that I need the codecs and a software program to do so. What do you experts suggests?
    Whoever told you that is either lying in your face or doesn't know enough information.
    In case your are wondering, NO you cannot turn your CDRW into a DVDRW by downloading a firmware for it.
  10. Seems to me your best bet is if you have a PC with a DVD-Rom to backup the DVDs to a format readable by a cd-rom. Plenty of guides on this site to tell ya how to do that...
  11. Member Cornucopia's Avatar
    If your programs are mostly shorts/trailers/spots, you could have a DVD "backed up" to a miniDVD (aka cDVD aka DVDonCD), but even this would require somebody to have a DVD-ROM drive to do the original backing-up. Also, you would probably need to recompress so as to have a lower bitrate to be within reasonable CD spin limits, and this will lower your quality somewhat.
    Time to take the plunge, huh?
  1. VCD cannot play in PC but can play in DVD player
    By avatar123 in forum Authoring (VCD/SVCD)
    Last Post: 3rd Jan 2011, 16:32
  2. Replies: 15
    Last Post: 18th Jul 2010, 12:55
  3. Reasonably priced media Player for the noobie..?
    By scharfg in forum Media Center PC / MediaCenters
    Last Post: 5th Jan 2010, 14:38
  4. Wi-Fi noobie confusion.
    By Xylob the Destroyer in forum Computer
    Last Post: 23rd May 2008, 11:59
  5. Noobie here
    By Explorateur in forum Newbie / General discussions
    Last Post: 25th Apr 2008, 15:59
