Can anyone recommend a program for the following: I've made a DVD of home movies. I'd like to add to the same disk a slide show of still photos that the viewer can flip through on a television screen using the forward and back arrow keys on a DVD player remote (as opposed to putting them into a video where each picture is displayed for a pre-set period of time). I've been using Sonic MyDVD and Arcsoft Showbiz because they came bundled with my computer, but they don't seem to support this function. I don't want to spend a lot just to add this feature, though.
Thread: Slide Show
If there is a way to do what you are trying...I dont know it but someone on this site probably does. I'll tell you what you dont want (putting pictures for a pre-set time) just in case you change your mind. You can use windows movie maker(its free and reletively easy to use) to make the file and I think it ends up as a mpg ready to burn. Good luck.
I believe that there was a post on this a couple days ago, and the posters there sugested a program called Memories on TV.
The other option might be to build a menu structure with the photos on them, then you can forward and backward through the menus with the photos as the background.
Photo Slide Show in AVCHD
By chrisnewton in forum Authoring (Blu-ray)Replies: 8Last Post: 23rd Apr 2011, 03:40 -
Making an interesting start to a slide show
By avz10 in forum Newbie / General discussionsReplies: 4Last Post: 16th Feb 2010, 23:57 -
Memories on TV Photo Slide Show program, help??? Please.
By vanc in forum Newbie / General discussionsReplies: 5Last Post: 28th Aug 2008, 12:34 -
DVD Slide Show Duplication
By KLouis22 in forum Newbie / General discussionsReplies: 3Last Post: 28th Aug 2008, 07:27 -
any way to make changes and not to encode entire slide show
By tryintoo in forum Authoring (DVD)Replies: 0Last Post: 9th May 2007, 17:02
Statistics
Newest guides
Latest tool updates
New media comments
