Hi,
I want to know the best way to convert from NTSC 29.97 frames per second down to PAL 25 frames per second?
Thanks to those who responds with the right answer
TurboRunner
I want to know also, from now i know the best method is making a MPEG-2 file and playback with RealMagic's MPEG-2 decode card....any good advice??
Please help
On 2001-07-09 00:16:24, TurboRunner wrote:
Hi,
TurboRunner
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
cant you just goto tmppgnc and use the vcd(palfilm) template
thats how it works right regular is 29.97 and film is 25 fps
right ??? check it out
You could... but the output video will probably turn into a horrible regular skipping mess.
Framerate conversions are HARD to do.
Regards.
Michael Tam
w: Morsels of Evidence
if u r lucky and have a copy of premiere, create a pal template, feed in your ntsc source then frameserve with avisynth to tmpeg with a pal template loaded. then premiere will work out all the frame resizing and framerate for you, with great results
720p conversion of PAL 25fps to NTSC 59.94fps using Handbrake?
By texas1 in forum Video ConversionReplies: 7Last Post: 29th Jan 2012, 11:06 -
29.97fps subs to a 25fps Video?
By solrage in forum Authoring (DVD)Replies: 34Last Post: 1st Feb 2011, 21:16 -
converting PAL (25fps) to NTSC(23.97fps) with audio
By drew24 in forum MacReplies: 6Last Post: 21st Dec 2009, 09:45 -
Help with HD @ 29.97fps to DVD at 25fps
By Killer3737 in forum Video ConversionReplies: 9Last Post: 19th Nov 2009, 14:29 -
avi is 23.97fps,srt is 25fps
By Soixante in forum SubtitleReplies: 7Last Post: 3rd Dec 2008, 14:26
