  1. I recently purchased a Toshiba sd2700 dvd player. I just burned a xvcd and vcd using different types of recordable cds. I have used Sony CDRW, Gigastorage, Professioanl Memeorex, and a few other brands. Everytime i play the movie it stops for a second a plays for a second. What should i do?? Is it the CDs, Nero, or my DVD Player?
  2. Member adam's Avatar
    check the dvd player list on this site and see what brands of cdr/w your player will read, if any.
    Download the sample vcd and xvcd disk images, burn them and use them to test so that you are sure the (x)vcd is compliant.
    Please only post your question in the appropriate forum, not all of them.
  3. Well i went and took a look. This is what it said
    CDR
    All
    Layer
    CDRW
    Silver
    Layer
    Im new at this. What does that mean
  4. What steps did u use to burn?
  5. I used nero to mak both a vcd and xvcd
    i just made my movie compliant and it burned to my cd but it dosent play properly
  6. Well it seems to work fine on my computer
    its just my dvd player
    my vcds work perfectly fine on my Phillips 825 but not my Toshiba sd2700
DVDFab DVD to DVD lets you backup DVDs to DVDr, AVI or MP4 for portable devices. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
