VideoHelp.com Forum
Results 1 to 18 of 18
  1. Did anyone figure out how to create compatible text scripts in order to be accepted by Adobe Encore DVD as a subtitle track? Or what program can create those from usual .sub, .srt, .txt files?
    Thanx.
  2. I am having the some problem, please anyone!!!
  3. Hi, there.
    Had the same problem so i made a small program that takes a SubRip.srt and convert it to something Encore understands. If you are interested you can DL it here:
    http://forum.videohelp.com/images/gu...subconvert.zip
    It converts to Unicode in a crude way but it works. Linebreaks too.
    Remember to check your subs for overlapping timecodes AND any lines starting with a number, even if it is the second line.
    Eg.
    00:00:00:00 00:00:03:00 300 soldiers went away...
    or
    00:00:00:00 00:00:03:00 They take all of the|300 cookies...
    will give you an error in Encore. Bad programming of a really good feature i guess. So fix these things before you import an things should work ok, at least it does with danish special characters.
    Comments are welcome.
    Happy authoring
    lightfoot
    lejf er en skøge og så dør han
  4. Thank you very much.
    Liru
  5. Hmm, just testet Encore with a fullscale subtitle
    Killed it after 2,5 hours of working. Lots of disk activity, 100% CPU and 1,5 GB RAM used.
    THIS SUCKS BIGTIME!!!
    Anyone else experiencing this
    Don't know how long it would have taken to finish the job, but it's way too long for me. He, and i thought ReelDVD was slow....
    Going to test FAB or Captions import before before giving up, hope that prerendered subs is a bit (lots) faster.
    Originally Posted by lightfoot86
    Hi, there.
    http://hjem.tele2adsl.dk/light/EncoreSubConvert.zip
    Eg.
    or
    Happy authoring
    lightfoot
    Hey man.. this totally rocks.. I like this and I appreciate what you have done. Peace bro
    To lightfoot 86. Ya it takes forever. Try setting it up before you go to bed and let it run all night.
    what? No man... it takes about 0.5 sec.
    I have a AMD 2800+ with 526 MB RAM
    Now the question is that if only importing your Subs takes the whole night then there is something diff wrong. Or do you ust import the AVI's as assets and run the Build DVD, cause then Encore would have encode your raw AVI to MPEG2 and also re-encode your audio.???
    What seems to be problem?
  9. has anybody fixed the importing problem? i simply cant import my srt files and the program from aboce doesnt wokr (no a valid integer (!?!))
    help?????!!!!!!!!!!!!
    Dude.. get the zip file from the link sbove...
  11. i use this program but i get this error.
    the subs are ok but it doesnt work
    See what line reference does it give you to. Then go to that line and check that the time given is not earlier than the previous times. Sometimes an error can occur. And then all the line numbers are in sequence so if you have a 200 after 365 then it will give you error, you need to correct the line number 200 to 366. I hope you got it!
  13. or use Subtitle Workshop
    and if you have Encore version 1.1
    upgrade to version 1.5
    version 1.1 its bugy and very very very slow with subtitles.
  14. can you let me know if i there is a way to automatically repair overlapped subs? i have the first in line 948 from 1450 and if i change them the next ones are at 980. if this goes on like it seems i have to reset a lot titels.
    is the a possibility to do that?
    thx... when i used encore 1.1 the workshop file couldnt be imported by encore. now it seems to work.
    The original download link for EncoreSubConvert is dead....
    So I re uploaded it here for you
    http://rapidshare.com/files/77234579...nvert.zip.html
    or
    Lightfoot86,
    a very useful tool , indeed. The only thing is that, it only converts succesfully subtitles that have a latin alphabet as a basis.
    No russian, japanese, greek, hebrew, etc.
    Is there any way I can avoid changing .SRTs for whole movies with another tool?
    Thanks!
    Kram
    Subtitling with Encore is not an easy task. So I use Subtitle Workshop 4. The problem is that although Subtitle Workshop CAN output .txt subtitle file compatible to Encore (ver. 1.0 to 2.0), it can't be imported to CS4 & CS5. This happens because Encore CS4/CS5 .txt must be UTF-8.
    Found the cure (!) guys please check my tutorial at http://blog.krama.tv/convert-srt-sub...be-encore-cs5/ and start using the best freeware subtitling application. Hope this helps
  1. Adobe Encore Subtitles ASCII
    By michcio in forum Subtitle
    Last Post: 24th Jan 2012, 16:30
  2. Adobe Encore DVD Question...
    By sdsumike619 in forum Authoring (DVD)
    Last Post: 26th Aug 2011, 05:46
  3. Replies: 2
    Last Post: 29th Jan 2009, 13:12
  4. Need an Adobe Encore DVD Guru for this one....
    Last Post: 9th May 2008, 19:24
  5. Adobe Encore 2.0 DVD Menu
    By ozab in forum Authoring (DVD)
    Last Post: 13th Aug 2007, 16:03
