I've been converting DivX AVI movies to mpegs using TMpgenc, trying to control the file sizes to get a couple movies on a DVD+R. I usually use the SVCD template in Tmpgenc, then set the Audio rate to 48,000. Or, I use the DVD template and reduce the encoding bit rate to about 3,000 kbps. I have a few questions on how I could do this better:
1) Which is the better way to control file size with minimum loss of video quality - frame size reduction or bit rate reduction?
2) If the frame size of the original AVIs vary widely, am I reducing video quality or wasting space by encoding at SVCD or DVD frame sizes?
3) Are there any other frame sizes I can use that are DVD compliant?
I mostly capture from TV and I have
noticed that a real long video works better if
you reduce to half D1 to make it fit instead of
reducing the bit rate at full D1
In other words 352 x 480 @ 2000Kbps looks OK
but 720 x 480 at 2000 kbps looks terrible
Question about Bit Rate and Quality
By T375 in forum Newbie / General discussionsReplies: 4Last Post: 20th Sep 2010, 09:31 -
How to achieve the maximum bit rate in variable bit rate mode ?
By Sxn in forum Newbie / General discussionsReplies: 42Last Post: 3rd Dec 2009, 12:53 -
Simple bit rate question
By Bully9 in forum Newbie / General discussionsReplies: 5Last Post: 8th Jan 2009, 12:01 -
Bit Rate And Frame Rate
By bharathi_n_r in forum Video ConversionReplies: 2Last Post: 30th Nov 2007, 05:48 -
optimal bit rates/codec/frame size for HDV on the web
By lafsunlmtd in forum Camcorders (DV/HDV/AVCHD)Replies: 19Last Post: 15th Aug 2007, 18:09
Statistics
Newest guides
Latest tool updates
New media comments
