While trying to back up a James bond movie in US with a US dvd using DVD SHRINK, I received the following message Copy protection error-the current dvd's region doesn not correspond to the region setting of the drive. I have a NEC dvd 1100 A. Does anyone have any advice. Thanks for the help
Thread: Drive Region Incompatible error
Exact same story only I was trying to back up the Disney movie A Bug's Life...
(Same Error - Same Drive - Same version of DVD Shrink)
I also tried to use DVD Decryptor to HD first and that failed also... I am wondering in it has to do with scratches on the disk...
Help appreciated
I think I found a solution to this region incompatibility error. I am using Anydvd which you can get a free trial of at www.slyfox.com. When you insert the dvd into the computer's dvd drive bay it automatically disables the region code. I then back up my dvd's with CloneDVD which i think is available at www.elby.com. These two applications used in conjuction seem to have bypassed any region errors I was getting before.
Good luck
VDub "incompatible data formats" error
By coyote2 in forum EditingReplies: 10Last Post: 1st Nov 2011, 11:28 -
How to reset the DVD drive region code?
By coody in forum DVD & Blu-ray WritersReplies: 13Last Post: 17th Apr 2010, 03:42 -
VirtualDub Error: The audio streams have incompatible data formats
By UMO in forum Newbie / General discussionsReplies: 4Last Post: 9th Apr 2010, 02:38 -
DVDRW drive cant read DVD Movies - Is it Region Locking or ... ?!?
By quantass in forum DVD & Blu-ray WritersReplies: 7Last Post: 8th Apr 2008, 22:45 -
ripping PAL Region 2 dvd to hard drive
By pattirose in forum Newbie / General discussionsReplies: 4Last Post: 10th Jan 2008, 01:30
Statistics
Newest guides
Latest tool updates
New media comments
