Load the ASF file in VirtualDub 1.3c, then attempt to convert to AVI (do the audio and video compression settings matter?). When the conversion begins, I get:
Sylia script error
expected ')'
Any ideas?
I'm trying to make some files I downloaded smaller in size (both physically (MB) and horiz/vert).
downloaded usally = warez
Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author
These are TV shows that I can watch anytime.
Call that "warez" if you want.
Convert all other versions of Virtualdub you have to zip files and store. Then delete all the originals. Then try again. Apparently The older versions of Vdub do not accept wmv files if newer versions are present on your HD.
ejoc:
Originally Posted by Baldrick
Thanks, mgh, that got me past that error.
Now, regardless of which audio compression scheme I choose, I get the error:
"Error initializing audio stream compression:
The requested conversion is not possible"
Any ideas on what to do there?
Try loading file in TMPGEnc without wizard-Use File-Output to file-wav. In TMPGEnc while loading select all files.
In Virtualdub-Audio-Wav audio..
That will probably work. I'm looking for a 1-step method to make it smaller. Just using TMPGenc worked and saved as an MPEG w/ lower resolution & audio settings. Thanks.
VirtualDub: "AVI Import Filter error: (Unknown) 80040154"
By Xavier in forum Newbie / General discussionsReplies: 4Last Post: 1st Nov 2010, 00:03 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 10:30 -
HDConvertToX keep getting "AVI files larger than 2000 MB" error
By jsbenson in forum Video ConversionReplies: 3Last Post: 4th Nov 2009, 21:20 -
Camtasia Error : "Unable to write AVI file frame"
By ShinuMirai in forum Newbie / General discussionsReplies: 8Last Post: 11th Oct 2009, 15:19 -
How to fix "twitchy' or "jerky" .asf files.
By bbanderic in forum Video ConversionReplies: 2Last Post: 21st Sep 2007, 17:48
