VideoHelp.com Forum
  1. I have a 40g internal hard drive that I tried capturing to and it works fine with no dropped frames but that hard drive is to small for capturing bigger projects. So I purchased a 2.0 usb external case and installed a 120g hard drive that I want to use just for capturing. When I capture to the external hard drive a get alot of dropped frames. My operating system is XP and I have a Pentium 3 with 256mb memory. I'm new to video capturing and I'm not sure what I should check and what I should do at this point. I'm using DVIO to capture from my mini DV camcorder. Thanks in advance!
    I'd really stay away from the external drives for capturing high resolution stuff. I had a 100GB external firewire, and the best I could get it to do without dropping frames was VCD projects.
    Install an additional, internal HDD and use that for captures.
  3. Member The village idiot's Avatar
    That's very odd. I "capture" DV from my RazzleDVBridge to an external drive all the time. And I do it from a P266 laptop with DVio. There must be some sort of conflict between your camera, the hard drive box, and your firewire card. Certain boxes will not work with my DVbridge, I get lots of dropped frames and other errors.
    What the answer to your problem is, I don't really know. You could try uninstalling the firewire drivers, and installing generic TI firewire drivers. Otherwise, try a different manufacturer for your hard drive box.
    Hold on a second, you said USB2 didn't you? How about exchange the USB2 box for a firewire box? It could be that the USB2 controller is hogging enough resources to mess things up.
    Try turning your antivirus off, and anything else that you have running. Disconnect from the internet if you have highspeed (unplug the cable), turn off any firewall software. Kill screensavers, all that stuff.
    Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
  4. Thanks for the suggestions,I'll give them a try.
  1. Capturing VHS to External Hard Drive...
    By the colonel in forum Capturing
    Last Post: 2nd Nov 2009, 19:34
  2. external hard drive
    By alintatoc in forum Computer
    Last Post: 26th Sep 2009, 19:54
  3. External Hard Drive > TV?
    By jason in forum Newbie / General discussions
    Last Post: 12th Mar 2008, 09:32
  4. Adding external hard drive
    By didikai in forum Newbie / General discussions
    Last Post: 2nd Mar 2008, 22:05
  5. Replies: 17
    Last Post: 24th Nov 2007, 08:47
