I'm having a problem loading SVCD2DVD. First thing I did was I uninstalled SVCD2DVDMPG+ from Control Panel Add/Remove program, then installed SVCD2DVD as normal. But when I started the program, it said "Registration is INVALID, Validation failure due to "XmlLoad"........" and then quit.
Anyone know how to fix this thing? Thank you in advance!
Thread: SVCD2DVD registration problem
Xero69Guest
Posted in the Sticky thread under Installation & Common issues"Validation failure due to XmlLoad"
This occurs because your reg file can't be found. It is supposed to be called reg.xml and reside in the INSTALL folder. The easiest way to do this is to open your INSTALL folder in Windows Explorer. Now open the zip attachment you recieved and drag the the registration file from the zip and drop it in your INSTALL folder.
Guesti did all that and it still will not no work
can you screenshot your svcd2dvd folder then
registration problem SVCD2DVD
By stgreene in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 8th Nov 2009, 00:32 -
Registration for product SVCD2DVD
By flurcoop in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 26th May 2009, 03:21 -
By brianbrian in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 1st Sep 2007, 14:08 -
svcd2dvd / vista registration issue
By simonlee in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 24th Jun 2007, 14:54 -
Registration of svcd2dvd
By error in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 18th May 2007, 09:34
Statistics
Newest guides
Latest tool updates
New media comments
