Ok I am looking to buy some surviellance cameras and I have questions, advise would be great.
1. What does the "lines" means? 480 lines ?? 360 Lines..what does that means. Does that make my video clearer, smoother and better quality if I have more lines in my camera ?
2. Capture cards for surviellance has different FPS. What does it means? There's a card that has four channel w/ 30FPS. So I guess 30FPS/4camera=7.5FPS each ?? So does that 7.5 FPS good ?? Is my video plays smoothly ?? and good quality in the video file?
3. With Motion Sensor Detection, does that comes as an option on the software with the capture card. Or an option built in with the camera?
Please help...Thank you,
Here is an excellent page describing FPS and what will be noticable and what wont.Originally Posted by Ekin
http://www.100fps.com/how_many_frame...humans_see.htm
There is no one answer to your question. There are many variables involved. For example, a human can identify a picture flashed in front of them for only a 1/200th of a second (or 200 FPS), but movies are shown at only 24FPS but are not jerky.
As for motion sensors, they could be either hardware or software. Hardware would probably be more expensive though."A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune
Also called lines of resolution. Standard for NTSC is 525 (or 515, I can't remember) lines for broadcast quality. The more the better!Originally Posted by Ekin
Chances are the one you are referring to can support four cameras and it probably records each at a rate of 30fps (an NTSC standard).Originally Posted by Ekin
It might be jerky as Solarjetman describes.Originally Posted by Ekin
Both. Software is just programming code and hardware is what will physical see motion with infared (?). But then again, the software will also have to know when to start recording.Originally Posted by Ekin
Ekin,
Try X10.com.
They sell anything from individual cameras to "Estate" security kits. They have a VCR Commander that turns on the VCR to record when motion is detected, more remote control stuff than you can shake a stick, mostly reasonable.
I have a bunch of the stuff myself.. The cameras are not DVD quality, but you would recognize an approaching person, if you knew him, of course.
They also have low light cameras.
Ahh! The never endings pop-ups !Originally Posted by gmatov
Shocker,
They do do that, don't they?
I haven't bought anything for over a year, my daily e-mail"sale" brochures finally stopped.
Still, it is reasonable, and works.
Cheers,
George
I haven't seen one in a while tho....
If the "click through" rate went too low, probably wasn't cost effective..
Kinda happy about that. Now if only some others would die.....
my current camera (jvc gr dv500) is messed up. making noises n weird lines
By bojadada in forum Newbie / General discussionsReplies: 4Last Post: 24th May 2009, 10:09 -
Vertical Lines from Video Camera
By solarblast in forum Newbie / General discussionsReplies: 0Last Post: 17th Mar 2008, 22:30 -
A quick simple and quick question.
By eros28 in forum Authoring (DVD)Replies: 2Last Post: 7th Dec 2004, 13:49 -
Help-Capture For Camera W/600 Horizontal TV Lines Resolution
By David.G in forum CapturingReplies: 0Last Post: 18th Aug 2002, 10:49 -
Quick Question, Quick Answer Needed
By bilbogod in forum Authoring (VCD/SVCD)Replies: 1Last Post: 22nd Dec 2001, 23:12
Newest guidesLatest tool updatesNew media commentsSlysofts AnyDVD HD removes DVD and Blu-ray encryption and region coding. More info or download trial! About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
