VideoHelp.com Forum
  1. Using dvd moviefactory 2 and discovered that it uses 8 gb of space of my c drive.
    I have moviefactory 2 installed on the D drive and i do not save any projects but burns the mpegs directly to dvd.
    How can it be that there is a c:\my documents\username\uleaddvd moviefactory\2.0\capture and working map that is full with .vob and .mpeg etc. when i do not save any projects?
    Can i delete these files?
    Do you people have the same in windows xp pro?
    Can i prevent it from stalling those files on my c drive?
  2. If i'm not wrong, make sure you have not checked create a dvd file and/or create a image file on HD (for future burns) at the final phase of burning process or just before clicking burn. This is the only possibility I can think of.
    If you do not need to re-burn the same movie, you can delete them.
    I choose save a copy on my hard drive for future burns!
    You can prevent ULEAD MovieFactory from creating these files in the future on your C drive by unselecting them just before you click burn.
    goodluck!
    Don't waste your media. Burn it on re-writable media first.
    Just to be on the safe side, you may also want to change the working folder in Preferences, as well as the Capture Folder, to someplace other than your C drive.
  1. Replies: 6
    Last Post: 6th Nov 2009, 04:54
  2. VOBmerge how much space is required
    By carlos28355 in forum Newbie / General discussions
    Last Post: 24th Jun 2009, 00:27
  3. Replies: 3
    Last Post: 3rd Jan 2009, 20:01
  4. Ulead DVD Moviefactory 5
    By Flying Doctor in forum Authoring (DVD)
    Last Post: 2nd Aug 2007, 10:43
  5. Questions about Ulead DVD MovieFactory 6
    By cheeseandcrackers in forum Authoring (DVD)
    Last Post: 18th Jun 2007, 10:46
