ok.. i have 4 slots for memory (up to 4G total) on my Asus P4C800 deluxe mobo..
i had 1G of Crucial/Micron DDR PC3200 (CL3) memory installed under my Win2000 setup. When i pulled up 'Task Manager', it clearly displayed that i had 2 channels up and running, i.e., showed me performance of 2 separate CPU's.. BUT...
i installed another 1G of Crucial/Micron DDR PC3200, only this time, it was CL2.5 and now my system is not in dual channel mode anymore.. ??
how do i get it to run in dual channel mode again?? i tried swapping up memory sticks into different slots, went into BIOS, etc.. but to no avail.. is it possibly b/c i'm running 2 different CL speeds??
please advise.. thanks.
Someone correct me if I'm wrong, but you need to install your memory in pairs in order for dual channel mode to work. You will not be able to run dual channel mode with an odd number of sticks of ram.
EDIT:
I just noticed that you added another 1GB of ram, which most likely means that you added another TWO sticks...sorry about that.
The differing CL is something I'd have to look into further to see if that is the culprit.
You probably already know this, but if you really want to take full advantage of dual channel mode, memory manufacturers sell matched pairs of ram that are optimized for performance as a pair. Not sure how much 'better' the performance is, and I'm sure you pay a premium for it
Open WIDE for Chunky!!!
You need to install memory in pairs and the ram must have identical specs for dual channel mode to work.
Thanks, juggernaut..
oh well.. anyone looking for a pair of Crucial 1G of CL3/PC3200/DDR400 memory (2 @ 512M)??
DDR memory as a hard drive..
By The Fred in forum ComputerReplies: 1Last Post: 14th Nov 2006, 22:25 -
3 memory slots and 'dual channel capabilities'
By donpedro in forum ComputerReplies: 12Last Post: 22nd Feb 2005, 10:10 -
Do Micron and Crucial memory play nice in dual channel?
By JSB in forum ComputerReplies: 3Last Post: 14th Dec 2004, 16:33 -
DDR memory question...
By tsantsa in forum ComputerReplies: 6Last Post: 7th Dec 2004, 08:39 -
Memory: DDR vs PC-133 ?
By nkhlystov in forum Newbie / General discussionsReplies: 2Last Post: 25th Dec 2002, 00:31
Newest guides
Latest tool updates
New media comments
Recent DVD Hacks
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
