I'm using the following tools:
1. DVDDecrypter
2. DVD2AVI
3. BeSweet GUI
4. TMPGEnc
5. Ulead MovieFactory 2
I succussfully converted a PAL DVD to NTSC DVD but the audio is only 2 channel stereo. How do I preserve the Dolby Digital audio?
During the mux'ing process, I imported the m2v file into TMPGEnc but when I tried to import the converted .ac3 file TMPGEnc displayed an error message informing me that the file type was not supported (or something to that effect). I got around that problem by using BeSweet and converting the PAL ac3 file to a NTSC mpg file (rather than PAL ac3 to NTSC ac3 file). I'm pretty sure this is where I "lost" the Dolby Digital audio.
Any and all help is greatly appreciated! Thanks in advance.![]()
There are two main approaches to converting PAL to NTSC. One method is to convert the frame rate to 23.976fps from 25fps and that requires a change in the audio. The other method does not require an audio change.Originally Posted by koolio
If you do the method that requires an audio change then simply run the original AC-3 through BeSweet and the BeSweet GUI using the built-in PAL (25fps) to NTSC (23.976fps) pre-set option.
You can go straight from AC-3 to AC-3 this way preserving your audio. If you have 5.1 AC-3 you can go straight to 5.1 AC-3 if you have 2.0 AC-3 then you go to 2.0 AC-3 but you can't go from 2.0 AC-3 to 5.1 AC-3 but that makes sense right?
Just make sure you use the BETA versions of BeSweet and the BeSweet GUI
For more info check out THIS thread:
http://www.dvdrhelp.com/forum/viewto...433&highlight=
Good Luck
Dolby Digital PLus (ac3) track to FLAC error
By Edgarke16 in forum AudioReplies: 0Last Post: 26th Sep 2011, 23:38 -
Dolby Digital 5.1 track?
By dstrahan in forum DVD RippingReplies: 1Last Post: 24th Jul 2011, 23:48 -
How do I preserve 1 audio track and change another?
By Han Solo1 in forum AudioReplies: 2Last Post: 7th Jul 2011, 13:21 -
Is it possible to convert MKV to DVD and preserve 5.1 Dolby sound?
By bija in forum MacReplies: 4Last Post: 28th Jan 2010, 08:10 -
From Dolby Digital AC3 to Dolby Digital Stereo and back
By moviebuff2 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Dec 2007, 19:54
Statistics
Newest guides
Latest tool updates
New media comments
