VideoHelp.com Forum
  1. I have a 320x240 MPEG-1 file, which I need to convert to 320x288 (PAL) to put on a VCD. Is there any program for the Mac that will do this (I know it can be done on Windows using TMPGEnc)?
  2. Member bugster's Avatar
    Moved to the MAC forum, you might get more help here.
    first, use Mencoder in the terminal to convert to a .avi
    mencoder -oac pcm -ovc lavc /path/to/input.mpg -o /path/to/output.avi
    This should not take too long.
    Open the resulting .avi in Quicktime and choose TOAST VCD EXPORT
    click on OPTIONS and select PAL and export.
    This will not only change your resolution, but change the framerate for you with ZERO loss in sync.
    Hope this helps.
  1. How to convert RM/RMVB to AVI or MPEG1/2
    By kschang in forum User guides
    Last Post: 11th Feb 2012, 19:56
  2. Convert for MAC
    By carbongixxer in forum Mac
    Last Post: 9th Oct 2009, 14:02
  3. Trying to convert WMV to MPEG1 on a slow processor
    By Gooey in forum Video Conversion
    Last Post: 21st May 2007, 03:59
