  1. I'm looking for owners of a Proline 1040 DVD Player. Are you able to play DVD+R and/or DVD-R? If so, could you please tell me which brand you use and how you burn them?? I'm having "NO DISC" problems when trying DVD+R discs, but according to the reviews it must be possible..
    Please help!!!
    Many thanks
    I get the same problem and its infuriating.
    Did you manage to find a solution?
  3. i have a Grundig gdv 250 dvd player which is identical to the proline 1040 player, both are not able to play dvd-R's or dvd+r's because of the hardware. There is nothing that can be done unless you take it to a shop and get the machine chipped as far as i know there is no firmware fix for this including the macrovision. I had to change dvd player so that i could watch my DVD-R movies.
    Check out the dvd hacks page you might get more info there on you proline dvd player
    Hey, thanx for the reply.
    Just wondered how some people manage to get it to work then - according to the reviews of the proline 1040 on this site people can get it to work with all disc types. Very confusing the whole thing.
    I have now managed to get a DVD+RW to work and am going to try with a DVD-R. If some people can get it to work then it must surely be possible....
    I have just got a set of DVD-R from dabs.com - the cheapest ones available - and they seem to play fine, so you might want to try them. Dont know what is wrong with the DVD+Rs i have...
  6. I have a other strange problem a dvd-r is playing a dvd +rw is playing a dvd - rw is not playing and a dvd + r is also not playing can someone explane that to me
  1. Jwin and Proline
    By Aviation in forum DVD & Blu-ray Players
    Last Post: 10th Aug 2006, 13:24
  2. Proline DVDP707W
    Last Post: 10th Aug 2006, 13:23
  3. Proline 1000
    By the womble in forum DVD & Blu-ray Players
    Last Post: 9th Jan 2004, 03:57
  4. How to use DVD+R with Proline 1040
    By JasperG in forum DVD & Blu-ray Players
    Last Post: 20th Dec 2003, 21:15
  5. Proline dvd 1040
    By SupaTek in forum DVD & Blu-ray Players
    Last Post: 21st Apr 2003, 14:40
About   Advertise   Forum   RSS Feeds   Statistics   Tools
