I used CloneDVD to make a copy of a DVD and cut out all necessary things (menu, extra's, etc..) EXCEPT dutch subtitles.
When I watch the copy on my DVD player, subtitles are not present (impossible to select).
When I watch the copy on my PC with PowerDVD: subtitles ok.
Any ideas?
thx!
Supergaazz.
This is a stumper that has yet to be solved.
I've been trying to copy a couple of DVD's for weeks, and nothing I do will carry over the subtitles for stand-alone players, yet every copy's subtitles work fine when I play them on the computer.
I've tried five different stand-alone players and four different DVD-ROM drives. Results are always the same; the subs won't work on the players, but they always work on the DVD-ROM drives.
It doesn't matter whether I keep the discs' contents intact or re-author, it's the same either way. The only consistant thing is that I always have to compress the movies for size. I think it's something in this compression that messes it up for stand-alone players.
I originally thought this was a DVD Shrink problem, but it looks like you're having the same issues with CloneDVD. Were you compressing the movie for size? (Can CloneDVD even do that?)
My other copies are working fine, also made them with CloneDVD. Perhaps it has nothing to do with it, but when I made my "working" DVD's, I kept the menu.
Perhaps that made the difference.
I think some DVDs have user protections. If you choose English language, you can't switch to French audio, for example.
DVD Shrink allow to disable them.
ffmpegX burned subtitles are missing with arabic (iso-8859-6) subtitles
By eswenson in forum ffmpegX general discussionReplies: 6Last Post: 11th Jan 2012, 08:22 -
I have powerdvd 7 ultra but i cant load external subtitles?
By leus in forum Software PlayingReplies: 5Last Post: 26th Jul 2010, 11:50 -
WD TV and missing subtitles
By Tommybj in forum Media Center PC / MediaCentersReplies: 3Last Post: 13th Dec 2009, 15:48 -
sub to srt: missing subtitles
By vidwhore in forum SubtitleReplies: 2Last Post: 9th May 2009, 15:50 -
Subtitles missing
By magmo in forum Blu-ray RippingReplies: 6Last Post: 2nd Jan 2009, 06:34
Statistics
Newest guides
Latest tool updates
New media comments
