i am totally new to this program so be gentle with me,,,, i am trying to back up a dvd that has 6 tv episodes on, run vcdeasy, program does the usual stuff and says complete, but when i go into the directory ive saved the file in , i only have 1 episode, in there, and the funny thing is , its the second episode on the disc? any help would be appreciated thanks!
Thread: help needed
I maybe suggest a different way. Use dvdshrink v2.3 beta 5, and rip the dvd again to ur HD. this way you will get everything from the dvd. Ive never used vcd easy, i use dvd2avi/tmpg encoder, but thats what i would do. i had a problem like that myself, so i had to do the whole dvd again this way....hope its helpful...SasArchiver
AMD 2200+ (1.83ghz), 512DDR PC2700 (333mhz)
160GB Hitachi 7,200rpm 1mb cache, 80GB Western Digital/7,200rpm HD
ATI Radeon 9600xt 128mb 8x, KT4 Ultra FSB 333 AGP 8X/ D bracket
DVD+R/DVD+RW/CD-r/CD-RW,Antec Plus 1000 Case with lights
YAAI help needed
By snafubaby in forum Newbie / General discussionsReplies: 3Last Post: 24th Apr 2011, 05:18 -
AviSynth much needed help!
By dbanimal in forum EditingReplies: 18Last Post: 28th Jan 2011, 10:33 -
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 12:27 -
Hack needed
By chisholmh1 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 31st Dec 2007, 10:32 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
Statistics
Newest guides
Latest tool updates
New media comments
