Converting Home Movies over to DVD and naturally the VHS tapes contain quite a bit of audio noise on the soundtrack. Did many searches and asked around on other forums (including this one) and got no replies. After a few hours of searching, I came across this program.
http://www.goldwave.com
This is a shareware program that I found very useful for removing Audio Noise. Those static pops, hisses and otherwise annoying sounds you get when you capture over from a VHS/8mm source.
So just load up your captured video into Adobe Premier (or Virtual Dub?) and save the Audio to a .WAV File. Load up GoldWave, drag and drop the .WAV into the work area. From the pull down menus, select Effects, then Filter, then POP/CLICK using the Agressive preset. After its done, run the Noise Reduction filter, using the Average at 75% preset. When done, save to .WAV and import it into Adobe for latter editing.
Bit of a hassle, but this makes a HUGE difference in sound quality.
Results 1 to 11 of 11
Or is there a better tool?
http://home.comcast.net/~officerfarva/before.mp3
http://home.comcast.net/~officerfarva/after.mp3
Note: Audio sample was taken from a wedding. -
depends on your budget - Waves makes a really nice set of plugins, the Restoration Bundle, but they are a couple of hundred bucks...
...and that doesn't include the basic editing application that you plug them in to...- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
I use a program called cool edit....I have been making music longer than video editing and cool edit has all the features you want in cleaning up wav files clip pop restoration hiss/noise reduction, normalistaion, you name it can just about do it....I highly rate this software..it is the best wav editing software ....besides industry stuff like pro tools cubase ....etc
How long could we maintain? I wondered. How long until one of us starts raving and jabbering at this boy? What will he think then?
If you like Tekno download one of my tracks
www.users.bigpond.net.au/thefox149 -
I've used WavePurity Standard to remove noise from vhs source audio with good results. Looks like it is priced at 30 Euros.
I agree with the Cool Edit guys. I use Cool Edit 2000 with the audio cleanup plug-in. I was shocked at how well it worked on my old 33rpm vinyl records I converted to CD. I have used it extensively to clean up clicks and pops in the audio tracks from old videos.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Well I must be doing something wrong, but I found a copy of Cool Edit Pro 2.0, which I believe had Audio Clean Up built into the program. Ran the static/pop removal and I couldnt tell the difference between before and after. Goldwave did a much better job and did it in a fraction of the time (10 minutes vs cool edits 45 minutes!!?).
What gives? -
go to www.syntrillium.com and get the noise reduction tutorial. it will explain why you didn't get any change in sound. Noise reduction is a two step process in which you have to sample the noise you want removed first and save it as a template. this works better than the generic static/pop removal. wave correcter is still the best at this.
I think ill stick with Goldwave, Adobe bought Cool Edit and merged it into their Adobe Audition software. That links re-directs you to the Adobe Audition support site, where if you type in "Noise Reduction Tutorial" you get a bunch of Adobe Premier links. If you Google the site, all you get are Glossary terms.
I dont think the site is setup properly yet. Thanks for the help.
How to remove audio noise?
By Leo48 in forum Newbie / General discussionsReplies: 4Last Post: 26th Jul 2013, 15:09 -
Remove noise from audio captured from VHS
By arminio in forum RestorationReplies: 8Last Post: 9th Feb 2012, 07:59 -
Noise from VHS audio - hard to remove
By dexter30 in forum RestorationReplies: 4Last Post: 8th Apr 2010, 07:15 -
How to remove noise in audio of mkv file
By maass in forum AudioReplies: 1Last Post: 11th Nov 2008, 03:08 -
how can i remove wind noise from a audio track
By suomiaussie in forum AudioReplies: 2Last Post: 23rd Mar 2008, 09:10
