Can i compress an avi to make it smaller so that i can burn it to dvd with ulead movie factory?
Thread: Avi compression???
Changing the avi does not matter if you are going to convert to DVD with Ulead dvdMoviefactory. In ulead movie factory should you instead lower the bitrate and you can also change the audio to mpeg if it wouldn't fit.
Under project settings can you change the video and audio bitrate so it will fit on one dvd
When i change these settings, the file size stays the same - too big.
Convert the file in tmpgenc to an mpeg and then load it into ULEAD
Help: AVI compression using virtualdub
By stan101 in forum Newbie / General discussionsReplies: 9Last Post: 14th Oct 2011, 21:55 -
Help with AVI compression.
By breeze9 in forum Video ConversionReplies: 6Last Post: 3rd Jan 2009, 02:06 -
ginormous avi (even after compression) What to do?
By hygieneboy in forum Authoring (VCD/SVCD)Replies: 6Last Post: 30th May 2008, 00:28 -
dv-avi(mpeg2) to avi compression
By nivek_nayr in forum Camcorders (DV/HDV/AVCHD)Replies: 11Last Post: 12th Feb 2008, 08:44 -
Best compression format for AVI's
By Smallan in forum Video ConversionReplies: 2Last Post: 19th May 2007, 18:13
