are there any dvd+rs that hold a full length commercial dvd on one disc? or do you have to burn them on 2 discs
Thread: burning commercial dvds..
Depends
Take a look to the left at "What is DVDR" also check the glossary:
http://www.dvdrhelp.com/glossary
for DVD-5, DVD9 and DVD-10, DVD-R.
This guide explains the how to backup DVD5 and/or DVD9 discs.
http://www.dvdrhelp.com/forum/userguides/141024.php
A DVD+R will hold almost exactly the same amount of data as a DVD-R.are there any dvd+rs that hold a full length commercial dvd on one disc? or do you have to burn them on 2 discs
Here are the numbers:
Blank DVD-R 4,489MB 4,706,074,624 bytes or 4.383GB
Blank DVD+R 4,483MB 4,700,372,992 bytes or 4.377GB
How do I make an edited compilation of several different commercial DVDs?
By WileE in forum EditingReplies: 8Last Post: 27th Nov 2010, 19:33 -
Remove Copy Protection Software/Encryption from Commercial DVDS
By dogojoel in forum Newbie / General discussionsReplies: 2Last Post: 14th Jun 2010, 21:54 -
Ripping and modifying commercial DVDs and menus
By rassilon256 in forum Newbie / General discussionsReplies: 2Last Post: 9th Feb 2010, 06:30 -
No video/commercial dvds
By vcrpro3 in forum DVD RippingReplies: 6Last Post: 31st Jan 2010, 17:02 -
Can't Play Commercial DVDs??
By PreciousGem_22 in forum DVD & Blu-ray WritersReplies: 7Last Post: 2nd Aug 2009, 17:09
Statistics
Newest guides
Latest tool updates
New media comments
