i re-encoded using tmpgenc it took 12 hours i burned to dvd and it plays fine and audio is perfect but framerate is messed up.. it is watchable, but theres a constant little skip in the frame what setting did i mess up?
framerate 23.9
i did 2 pass vbr
3:2 pulldown
vbv buffer (automatic)
could it be if i picked the wrong source aspect ratio
i used 16:9 and it might have been 4:3
field order i used top field first
and in dvd2avi when i used that in the begining i used forced film i dont know if i was suppose to
The only thing I can think of it being is that you selected "Top field first" when the movie was "Bottom field first" or visa versa, try it out on a small sample and see if it works.
The problem is that you changed the framerate through frame decimation, rather than slowing it down properly. As a result you have randomly lost a frame each second and that is why you see the skip.
To convert PAL to NTSCfilm (23.976fps-> which will be played back at 29.97fps) you simply want to slow it down, keeping all of the frames. To do this in TMPGenc you need to enable the "do not framerate conversion" filter on the advanced tab and set output framerate to 23.976fps.
Now, since you are physically slowing down the speed of the film, rather than just throwing out frames, you will also have to slow your audio playback speed as well. For this use BeSweet. In the lower left hand side you will see presets for various regional format conversions. Select the PAL->NTSCfilm option.
Converting a "variable framerate" to constant framerate?
By vieo in forum Video ConversionReplies: 6Last Post: 2nd Sep 2010, 09:05 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
Problems with CMD-850 PAL to NTSC conversion
By vwy33 in forum Video ConversionReplies: 18Last Post: 31st Jul 2008, 07:55 -
Problems with Documentary trying to use both PAL and NTSC footage
By Lucy in forum MacReplies: 5Last Post: 24th Jun 2008, 15:57 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19
Statistics
Newest guides
Latest tool updates
New media comments
