Thank you!
Regards,
Joe O
Not enough info here to respond properly. Why don't you just throw in a disc and try to burn it and see. Should only cost you a few cents, unless you bought your CDs at the supermarket. I know that VCDeasy is always finding errors of some kind, but I just burn the disc anyway and it seems to play. If you got the 'error' message while you were still in TMPGEnc, then you probably have a real error. Just re-render and see if that fixes it. (especially if you processed the sound thru TMPGEnc.) Sorry but I don't know what 'update scan offsets' means. I'm still sort of a newbie too.
I've asked this q too, as I always get this warning. I think Vitualis answered it: It's some pretty old compatibility issue, and will not affect SVCD playback. Just ignore it.Where can I set "update scan offsets" and what will this do?
/Mats
Just go to the VCDeasy setting page and turn off the "update scan offsets" warnings. You will not see the warnings again and hence not worry you. VCDeasy burns with these Tmpg files with no problems on playback.
your err-or message is probably somnething to do with being non compatibe eg it is not 100% correct. It may have 48khz sound or non closed gops. Burn it to a CDrw and it wont even cost a few cents. Also fully close tmpgenc before opening its output file (it can take qute a few minutes to finish writing out its file).
VCDeasy cant fix nothing.Corned beef is now made to a higher standard than at any time in history.
The electronic components of the power part adopted a lot of Rubycons.
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 08:58 -
Batch "file creation from a text file, Placed into a created directory
By Muther in forum ProgrammingReplies: 2Last Post: 4th Jan 2012, 01:44 -
Installing Problems, No file created
By jburkhardt in forum ffmpegX general discussionReplies: 8Last Post: 1st Nov 2008, 22:56 -
Getting error loading mpg that svcd2dvd created
By scoooter1 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 1st Oct 2008, 12:14 -
HDTV2DVD - Any way to prevent .MPG file from getting created?
By geek2330 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 8th Oct 2007, 20:00
