For such a long time I have been facing the sync problem. The mpeg2 file I captured can be played synched, but whenever I edit it, like cutting away the commercials, the resulting file is very likely to be out of sync. But now I found a way to keep it always synched.
Here is how I do it,
1) Capture the mpeg2 file with Pinnacle Moviebox. This file is perfectly synched when played, but it is not editable, because this would cause desync.
2) I demux this file with PVAstrumento. I unchecked all the options under video and expert, and also unchecked fix startup delay under general. Here I would get one audio and one video file.
3) I mux the audio and video files back together with Womble mpeg2vcr.
The resulting file is what I am looking for. It is perfectly synched, and no matter how I cut and join it, the output is always synched. And I like to use Womble mpeg2vcr for cutting and joining because it is really the fastest and easiest I have ever used.
Try to see if you get the same result, and post a reply here.
Combining synched sound with video - total absolute newbie
By Povster in forum Newbie / General discussionsReplies: 2Last Post: 24th Mar 2011, 16:37 -
finally my mac
By scarlac in forum DVD RippingReplies: 5Last Post: 23rd Apr 2010, 02:54 -
export subtitles created/synched in Authoring Works
By ecc in forum SubtitleReplies: 1Last Post: 21st Feb 2009, 18:44 -
BD+ finally cracked...
By ntscuser in forum Latest Video NewsReplies: 12Last Post: 25th Nov 2007, 07:14 -
Audio and video not synched when authoring HD-Mpeg2 to DVD using Moviemaker
By edong in forum Camcorders (DV/HDV/AVCHD)Replies: 0Last Post: 24th Sep 2007, 17:44
Statistics
Newest guides
Latest tool updates
New media comments
