Does anyone know if there is an existing command line I can use to automatically switch my video card (All in wonder 7500) to TV out? I am looking to be able to turn on the TV display with my Remote Wonder.
Thread: TV out command line
open up the remote wonder software (double click icon in the system tray), give one of your remote keys (A-F) an assignment of, say F8, then...
go to the ATI control panel to turn on the TV out, then assign this a hotkey which you used in Remote Wonder, i.e. F8 (click in the hotkey box then press F8), give this scheme a name and save it.
Then anytime you hit the Remote button (A-F) it will automatically switch on the TV-out.
Be sure to use a hotkey in both instances which you dont generally use when using windows, and do it in this order or it will never work.
How to Use x264 Command Line
By Jeff B in forum Newbie / General discussionsReplies: 30Last Post: 20th Dec 2011, 15:56 -
Command-line command for fixing AVI?
By timur in forum ffmpegX general discussionReplies: 1Last Post: 23rd Sep 2009, 02:23 -
best way to record tv from command line
By mierdatuti in forum LinuxReplies: 1Last Post: 17th Jun 2009, 02:08 -
A-B repeat in command line
By alexandre_fs in forum Software PlayingReplies: 4Last Post: 15th Jan 2009, 15:35 -
command line
By exekutive in forum ffmpegX general discussionReplies: 22Last Post: 1st Jun 2008, 23:44
Statistics
Newest guides
Latest tool updates
New media comments
