VideoHelp.com Forum
  1. I have a video, the filesize is 200MB with mpg-1 format (VCD).
    Now I want reduce it file size to < 150MB.
    I already tried few softwares -- VirtualDub, Ulead video studio 6.0 and TMPGEnc. Those software make video filesize big than 200MB.
    Is there any software can help to reduce video filesize ?
    I had few VCD movies which got from Hong Kong, Each CD have four movies, each movie over one hour long. I don't know how they can make those VCD ?
  2. Member bugster's Avatar
    Assuming you want it to remain mpeg-1, the only way is to reduce the bitrate.
    With mpegs, the only things that affect filesize are bitrate and playing time. Use a bitrate calculator to find out what bitrate you need to achieve the required filesize, then re-encode with TmpGenc.
    VCD spec allows approx 10Mb per minute of movie and they are stored in a different mode to normal data CD's, so you can get 80mins of VCD on an 80min CD.
  3. Member thayne's Avatar
    VCD mpegs have a fixed bitrate and resolution. You can make an xvcd with a non-standard bitrate, but it may not work. Why do you need to cut it to 150MB? 4 200MB mpegs should fit onto a 700MB CD when authored as VCD
    VCD's aren't data disks and you can fit just over 800MB onto a 700MB data CD.
  1. How to reduce filesize and to not lose too much quality?
    By xxxThiefxxx in forum Blu-ray Ripping
    Last Post: 9th Aug 2011, 08:48
  2. Why is Sony Vegas only 200mb and other editors a few GB?
    By vidds in forum Newbie / General discussions
    Last Post: 17th May 2011, 04:11
  3. Reduce MPEG-2 filesize without losing too much quality?
    By yic17 in forum Video Conversion
    Last Post: 4th Apr 2009, 16:59
  4. Muxing MKVs adds 200MB
    By XenoPhex in forum Mac
    Last Post: 3rd Mar 2009, 23:33
  5. Reduce VOB filesize
    By jacktorrance in forum Video Conversion
    Last Post: 14th Jan 2009, 11:34
