VideoHelp.com Forum
    what is my best choice/best quality and fastest export for a movie in imovie. it is about 7 hours now! I want to try to put the entire length on a single DVD (willing to accept quality loss) idvd will not let me do anyhting onger than 1.5 hours. But I want it to play in a normal dvd player
    any suggestions?
    I do have Toast if it helps
    thanks guys
  2. (1) imovie3 has a "reference" movie that imovie uses and other mpeg encoders can probably use too -- but not bitvice, ime. i get bitvice to work by . . .
    (2) exporting the movie from imovie. i choose export -> for quicktime and select "full dv" as my quality setting. you can also choose export for idvd -- same thing afaik. however, it sounds like you are . . .
    (3) trying to encode the movie to make it "fit" in idvd. that won't work. encoding the movie to a "smaller" format will not change its length -- which is what idvd uses. 90 minutes is 90 minutes regarless of your mode of export. thus, you can . . .
    (4) either (a) cut you movie to 90 min and use idvd per above or (b) keep your movie at over 90 min, encode with bitvice (lite version $56 -- great quality!) or something else, author with sizzle or something else, and burn with Toast or something else. hth.
  1. Replies: 4
    Last Post: 11th Dec 2011, 20:05
  2. Exporting VHS burn from IMOVIE HELP!
    By durdenwasright in forum Mac
    Last Post: 23rd Oct 2009, 08:35
  3. vegas exporting
    By romanstopme in forum Newbie / General discussions
    Last Post: 5th Apr 2009, 15:22
  4. exporting imovie video for web streaming
    By beforethedawn in forum Mac
    Last Post: 23rd Oct 2007, 09:56
  5. Replies: 3
    Last Post: 29th Jun 2007, 18:52
