I posted a bit ago about problems making a copy of a DVD I burned on a Philips DVDR75. Disks from that unit open on a Mac with two folders -- one is VIDEO_TS and the other is VIDEO_RM. Does anyone know what the latter is, and if it is somehow related to the difficulty copying one of these? Thanks.
Thread: What is VIDEO_RM???
Well, what's inside it, and how big are they on average? Does it work ok if you just copy that folder to your HD in the Finder and add it to the folder you rip the VIDEO_TS folder to? Does it work if you only have the VIDEO_TS folder? One possible tool to use to rip if the two cases above don't work is OSEx in DVD Image format. It takes forever, but is very compatible.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
Here's what's inside:
VIDEO_RM.IFO, 32K
VIDEO_MN.DAT, 4K
VIDEO_RM.DAT, 1MB
VIDEO_MN.IFO, 4K
VIDEO_RM.BUP, 0K
I could not copy to the HD -- got a -128 error message. Copied individually to a like-named folder, "seemed" to work but the file above that is 0K was 2K in the original. Not sure if that is significant. But I am adding to folder VIDEO_TS is in. We'll see if it works.
I can make a DVDBackup of just the VIDEO_TS folder, but if I try to go to disk I get "invalid media file" message.
I will tey OSEx if the above doesn't work.
Thanks for your help.
No go. Unless I make a disk image, nothing seems to work at all. Tried OSEx but it crashed if a disk was inserted. See my other recent post... I can get this work using Toast disk imaging (which does copy the VIDEO_RM file) but it will not work in all players.
So, I guess a recap:
-- burning with the VIDEO_RM, works in all players except Pioneer
-- burning with just VIDEO_TS, works in only Pioneer.
There has to be some pro out there who those why this is, right?
Thanks for any advice.
as far as I know the RM files are only for navigation on a SETOP DVD RECORDER
Not a PLAYER..I'm told the player doesn't need these....
I thought they were just there in case you want to record again on the blank
http://forum.digital-digest.com/arch...c/23311-1.htmlWith Phillips recorded dvd's you dont get two folders as in VIDEO_TS and AUDIO_TS....like you do on a normal dvd.....
You get two folders called....VIDEO_TS(like normal) and VIDEO_RM(the RM folder contains DAT files, IFO files,and VIDEO_RM.BUP files)
The strange thing is that if i want a copy of a phillips recorded dvd, i just rip it and burn the VIDEO_TS folder..as you normally do (using this method it doesn't burn the VIDEO_RM folder).
Or i just do a dvd copy with the Nero wizard (in this case it burns the VIDEO_RM folder too)
This is very strange, because the dvd's are playable whichever method i use to burn them.
Therefore: the VIDEO_RM folder doesnt seem to be doing anything really?
Why VIDEO_RM folder ?
By cyflyer in forum DVD & Blu-ray RecordersReplies: 48Last Post: 8th May 2011, 01:25 -
VIDEO_RM and VIDEO_TS Files Into Microsoft MOVIEMAKER and Post Online
By PanMan in forum Newbie / General discussionsReplies: 3Last Post: 10th Apr 2010, 20:49 -
very basic question: can I burn a DVD from video_rm & video_ts files?
By glitterla in forum MacReplies: 3Last Post: 25th Feb 2010, 12:09 -
video_RM file structure
By West3360 in forum Newbie / General discussionsReplies: 7Last Post: 16th Sep 2007, 13:19
