I want to grab just a 3 sec scene from a dvd disk. I want to do this for many scenes on diff dvd's .. like cataloging just certain tiny clips ..
I dont want to rip the whole damn dvd to my hard drive and load it into an editor just for 3 secs of vid
I would like to find some capture program program .. that can capture from a dvd .. just 3 darn secs .. grin
Thanks alot
Mike
You can use DVDShrink - just go to re-author mode, select the title and set the portion you want to rip - it will rip to a playable vob.
Don't know what you can do from there - I did see that the DVDShrink might support combining multiple DVDs.
You can use DVDDecrypter in stream mode and rip just the chapter with the clip you want. Then open the VOB in Virtualdub-Mod, select in and out, then save as avi or frame serve to TMPGEnc for MPEG-2.
You can also try a screen capture recorder program. I think even WMV 9 encoder will let you do this. While playing the dvd on your PC, just hit record on the scene you want and save as avi.There is no such thing as "Idiot-Proof".........a good Idiot will get around that every time.
I did the dvdshrink thing .. and it worked very nicely as far as making a vob with just the scene I want in it .. BUT.. Ill be damn if I can find anything to open the damn VOB except COPYTODVD .. which will only write to a dvd.
I tried DVDDecrypter .. and I played with it for an hour .. I must be an idiot .. I can NOT make it open a VOB
I tried every util I have .. including virtual dub .. and nothing will open the vob file ... at least I couldnt finger it out.
Mike
Jim
A capture card will do you better using standalone player.
Thanks guys ..
I do alot of home movies for me and family .. ( what a blast ) .. and I want to build up a collection of one liners .. so that when my wife says something dumb on a movie I am making .. I can have Jim Carrie come on and say .. REEEEAAAALLLLLYYYY .. or some other silly thing like that ..
so I just wanted to build up a collection of one liners, and didnt want to have to rip a whole movie to get just one.
ok .. I got dvdshrink to save a nice little 3 sec dvdmovie (vob ) now .. I need to be able to change it into a avi or mpg ..
got to be an easy way ..
PowerDVD and other players will open it .. but .. they only save single shots, not 3 sec clips
Sure. Use Virtual Dub MPEG-2 mod (no other version will load VOBs).
Hello.
1080i 29.97 frames/sec to DVD compliant SD using Avisynth and HC encoder
By johnnyquid in forum Video ConversionReplies: 2Last Post: 25th Jul 2011, 15:24 -
Recording 1080i 60 fields/sec vs 1080p 30 frames/sec
By johnnyquid in forum Camcorders (DV/HDV/AVCHD)Replies: 4Last Post: 4th Apr 2011, 06:38 -
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 15:35 -
is there any way to grab this particular video?
By Razvan007 in forum Video StreamingReplies: 10Last Post: 9th Feb 2010, 14:50 -
Only first (of 20) scene viewable from DVD-Cam disk?
By t88dv in forum Camcorders (DV/HDV/AVCHD)Replies: 8Last Post: 12th Sep 2007, 20:47
