VideoHelp.com Forum
  1. Hello there,
    I have made several working backups of my dvd, but i can't get ".hack//SIGN vol1" on DVDR the copy procces is going allright (backup with DVDBackup 1.3, shrink it with DVD2oneX. and finally burn it as DVD in Toast) but when I want to play the DVD on a standalone dvd player, it only plays from the piracy warning till the last studio intro.. after that I come to the screen where i have an image from attached to this topic where it just stops.
    Maybe it's an extra copy protection apart from the encryptions but i really don't know for sure.. the DVD is a BANDAI release so maybe they do that on all their discs and someone else has had that problem too.
    can anyone help?
    I have tryed this post on the other DVDR->DVDR category, but without luck.. cause i use an Mac maybe..
  2. Member WiseWeasel's Avatar
    You were doing Disc Copy mode in DVD2oneX, right? Movie-only might mess up if you chose the wrong title, or it might just mess up on some authoring jobs. Are all the VTS sets in the output VIDEO_TS folder from DVD2OneX? You got no errors anywhere along the line? Does the VIDEO_TS folder behave the same way when you play it off your HD with DVD Player?
    I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
  3. to make some thing clearer I have put here the steps to answer jour questing on my topic.
    1. Made backup with DVDBackup 1.3 (also did a copy with DVDExtract).
    2. Then I opened the "back-uped" VIDEO_TS folder from my HD in DVD2oneX.
    3. With DVD2OneX i made a "Disc Copy" (Not movie, cause i wanted to keep all the extras and stuff too.)
    4. After that I created an AUDIO_TS folder and burned the new VIDEO_TS and empty AUDIO_TS folder in Toast as a DVD (in the "other" tab above in toast)
    Also the backup plays fine on the HD, even when I put the new backup into my computer (the one I made the copy with), the DVD plays just fine like it should.. but after inserting the same disc into another player, then I get my problem.
    I also made about 10 working DVD backups wich i made the exact same way.
    thx for your reply
  4. Member WiseWeasel's Avatar
    Did you let Toast verify the DVD after burning it? Also, I've found that on some dvds, if I make an AUDIO_TS folder and the original didn't have one, that it won't work right. Did the original DVD have an AUDIO_TS folder? Try just burning the VIDEO_TS folder alone to DVD-R, so you have a DVD containing only a VIDEO_TS folder and nothing else. It's a long shot, but I've had that problem before.
  5. Hi Wiseweasel,
    I tryed out your new tip by backing it up again,
    shrinking it, and the burning only the VIDEO_TS
    folder on a dvd, and i've let it verify..
    still doesn't work either.. but i found something new out
    the picture i had send in my first post (above) is comming
    from a folder called JACKET_P on the original disk.
    You may be asking: how does that folder come in your
    backup.. well that's because on my 2nd try I also copied
    that folder to make sure i wasn't missing anything...
    In my latest test (3rd) wich I where following your tip
    I didn't burn that folder... so after the intro's i goes
    to a black screen..
    Where still not any further but i can only tell what i've found
    out.. below is an little extra piece of info on the DVD, I hope
    you can do something with it..
    DVD MAIN FOLDER:
    AUDIO_TS
    JACKET_P <- more info below
    VIDEO_TS
    DVD JACKET_P FOLDER:
    J00___5L.MP2 <- can be opened in LiveType from FinalCut Pro
    J00___5M.MP2 <- can be opened in LiveType from FinalCut Pro
    J00___5S.MP2 <- can be opened in LiveType from FinalCut Pro
    the L, M, S probably stand for LARGE, MEDIUM, SMALL..
    I also wonder if there's an IFO editor for Mac OSX
    thanks
  6. Member WiseWeasel's Avatar
    Hmm, well, you've tried pretty much everything I can think of, and if Toast isn't getting an error, then it's probably something about what DVD2OneX is doing to that movie that makes it unplayable in that player. I would suggest to just keep the backup you made for watching the extras on a computer or a different DVD player, and make a movie-only backup with DVD2OneX for use with that DVD player. Or else, you could find a PC (or Virtual PC) to run the freeware DVD Shrink v3, which is quite good for shrinking.
  1. Blu-ray backup won't play in PS3
    By DGenerateKane in forum Blu-ray Ripping
    Last Post: 27th May 2010, 00:57
  2. backup dvd with menu
    By wingfan in forum DVD Ripping
    Last Post: 19th Nov 2009, 23:01
  3. Replies: 3
    Last Post: 2nd Aug 2009, 05:13
  4. DVD Won't play past menu on laptop
    By DVDLovers in forum Newbie / General discussions
    Last Post: 11th Jan 2008, 12:24
  5. Simple Menu but movie won't run - TMPGEnc DVD Author 3
    By gayclarke in forum Authoring (DVD)
    Last Post: 14th Sep 2007, 09:00
