Here's the lowdon:
I had set up a SVCD profile to record a movie. The bitrate I planned on using was pretty low, so I tested it out by capturing somethingusing the encode interlaced option and then capturing it but this, time de-interlacing it so I could check it better on my PC. The bitrate was OK. This is a normal everyday thing I do before capturing, the only difference was that this time I had set the profile to deinterlace.
The problem:
I set the profile back to capture interlaced and captured the movie. I played it back on my PC, and to my horror it was de-interlaced, with the audio out of sync in places.
Is it just another bug with MMC 8.1? As I said, the only thing I did differently was a test capture with de-interlacing before I changed it back to interlaced.
Results 1 to 1 of 1
Thread: MMC 8.1 De-Interlacing
Good Video Explaining Interlacing and De-Interlacing
By Soopafresh in forum Newbie / General discussionsReplies: 3Last Post: 14th Aug 2008, 19:50 -
Distortion @ Bottom w/AIW MMC and Best JVC/MMC Settings??
By Offroad in forum CapturingReplies: 7Last Post: 14th May 2004, 23:45 -
Unable to play certain videos in MMC 7.6, MMC 7.1 no prob
By GLADIATOR 2002 in forum Software PlayingReplies: 0Last Post: 21st Jun 2002, 23:04 -
Stinkys MMC Reg Tool Updated to work with MMC 7.6
By Stinky in forum CapturingReplies: 0Last Post: 16th Mar 2002, 20:49 -
Need A Few Beta Testers For MMC Reg Tool (Updated for MMC 7.
By Stinky in forum CapturingReplies: 11Last Post: 18th Dec 2001, 00:06
