I am having an audio problem with my DVD. I use TMPGEnc DVD Author to make my DVDs and I use TMPGEnc to encode my avi files to MPEG2s. The audio problem is that the sound comes in great only through the TV. The audio that is sent to my Surround System (Onkyo Stereo) does not come in. All other DVDs work fine!! My DVD player is a Pioneer DV-C503. I don't know why the sound will not come in or what I need to do to make the sound at least go to my system in Stereo.... any help would be great.......thanks!
Thread: DVD Audio Problem......
Hmm? My first thought is that your DVD player doesn't like the mp2 audio (produced by TMPGEnc when it encodes MPEGs). You might want to demux your current MPEG2 file, and re-encode the audio as ac3 then author your DVD.
http://www.doom9.org/audio-guides.htm
I had the exact same problem, i've no idea if it's specific to make of DVD or to do with TMPEGEnc DVD author, anyway to get sound through your home cinema amp you need to change the audio settings on your DVD player to output PCM not BITSTREAM. This is a pain, which is why I now use BeSweet to encode the audio to AC3 (surround) and it works perfectly, outputting a standard Bitstream signal to my Yamaha Home Cineam amp
Is BeSweet easy to use? I downloaded it but I haven't tried to work it yet.....Originally Posted by coleman83
- check if your dvd player do need to enable mpeg audio
- does your dvd player connected only by a digital cable to your receiver, if yes, the analog mpeg audio won't play, try to connect simple stereo RCAs too, so the analog audio can go through
Zoltan
thanks for replying,,,, I do use a digital cable to my receiver. My concern is that I have used Sonic MyDVD ni the past and the sound comes through my stereo under "Pro Logic" which is fine! I wonder why it works for MyDVD and not for TMPGEnc DVD Author....I am using TMPGEnc DVD Author as a trial and I like it, but this audio thing is making me think of looking at other software!!! any ideas about the sound....Originally Posted by I_Can
DVD audio problem
By ra300z in forum DVD RippingReplies: 4Last Post: 7th Jun 2009, 11:21 -
Burning DVD audio problem
By Jragon16 in forum Newbie / General discussionsReplies: 4Last Post: 7th May 2009, 22:20 -
Audio problem on converted DVD
By ssalim in forum Video ConversionReplies: 4Last Post: 26th Jan 2008, 18:07 -
Audio problem with DVD FLICK
By mart59a in forum AudioReplies: 1Last Post: 20th Jan 2008, 14:54 -
DVD Architect Audio problem
By Just Mike in forum Authoring (DVD)Replies: 3Last Post: 12th Aug 2007, 01:11
