I followed "Digitoast"'s guide and found 352 bad frames and they were all in sequential order, so I masked them as mentioned in the guide.
The problem now is that the audio is completely out of sync with the video, i think this could be because i used Vdub-mp3 and so it did not cut out audio when it masked the bad frames and thus the resulting lag.
Can this problem be fixed by extracting audio as Wav file and using it when creating .mpg file for Xvcd?
Any ideas?
Results 1 to 11 of 11
Why dont you just DELETE the bad frames, That will
delete the audio too.
Originally Posted by FOO
I did not know how to do that, and so when I was searching for an answer, I found the guide and thought this would take care of everything.
But If I am not mistaken, it can be done by checking the video for errors using Vdub and then going back and simply masking those frames?
Can anyone confirm this? Or suggest an easier way if there is one.
Don't Mask them, Delete them.
Pick a range of video and hit the DELETE Key
How do you do that? Do I need to identify the bad frames before I hit delete, I mean mark the start and end frames and then hit delete?
Any ideas how to go about this?
The delete key will delete the single frame that you are looking at
Hi, I apologise up front that this won't help solve your problem - but you may be able to help me.Originally Posted by Cataphract
I have the same problem and it sounds as if deleting bad frames (and attached audio) may help. Can you point me to "Digitoast's" guide that you mention?
Cheers.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
It's here.Originally Posted by daamon"Art is making something out of nothing and selling it." - Frank Zappa
Thanks ZippyP - Much appreciated.
Sorry it took me a while to say "Thanks" - Just came back to this post and realised I hadn't!!!There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
You're welcome.
VirtualDub - fixing bad frames with blending and without re-encoding
By spicediver10191 in forum Video ConversionReplies: 3Last Post: 11th Apr 2012, 08:15 -
fixing 'out of sync' audio in video file
By Nonamer in forum AudioReplies: 10Last Post: 19th Feb 2011, 01:03 -
fixing bad frames
By vidclip in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2010, 15:00 -
Fixing / Determining Audio Sync Issues With Only Some DVDs
By TheNut in forum DVD RippingReplies: 5Last Post: 12th Dec 2009, 17:47 -
Fixing bad resampled DVD audio
By silverwolf0 in forum Newbie / General discussionsReplies: 3Last Post: 6th Jun 2009, 10:59
