I have been trying to update my sony dru500ax from 2.0c to2.0f. I've
read about the update but it seems no one is having the same problems as
I am having. I get a pop-up message saying I need to reinstall
"sendcom.dll", what is sendcom.dll.
Thread: sony firmware 2.0f can't update
It has been a while since I updated my 500A (internal) firmware, but have you looked at the downloaded firmware? I seem to recall that sendcom.dll was a part of it.
What I would do is search the computer using the search or find function of Windows unless it's a Mac. Find the file and rename it just in case and try the firmware upgrade again. Also you could go online with Sony tech support since you should be under warranty yet and use the tech support chat function over the internet.
Good Luck
blu ray player firmware update removes media compatibility sony bdp-s300
By cdcutlip in forum DVD RippingReplies: 9Last Post: 8th May 2011, 02:03 -
sony DAV-DZ100 Firmware update problem
By kanu in forum DVD & Blu-ray PlayersReplies: 3Last Post: 11th Nov 2009, 05:15 -
Where to Get Firmware Update
By Teac23 in forum ComputerReplies: 1Last Post: 26th Apr 2009, 13:52 -
update firmware
By avextraxjp in forum Newbie / General discussionsReplies: 6Last Post: 12th May 2008, 22:46
Statistics
Newest guides
Latest tool updates
New media comments
